1 - 7 of 7 Posts
Here is what I’m building for 2014. My block is at the machine shop for boring and my rotating assembly is getting balanced as well. You will notice I didn’t list the cam yet, I ordered a custom solid flat tappet cam and lifters from Scotty J and I haven’t received it yet but it’s 260/272 @ .050, 109 LSA and 105 ICL...That's it for now. I hope to be on the dyno in 2-3 weeks. :D Expecting to see 600-625HP and maybe a 9.? time slip if my weight calculations are right and she hook's up.:D
460 D1VE block, bored .060", decked by previous owner (unsure of exactly how much yet) 472" CID
2YABC crank with King bearings
Eagle H-beams
Carl’s custom dual flycut forged Probe pistons (P51 or SCJ) 15cc dish
Speed Pro rings
Dave Freelander’s A429 heads from the “Cheapskate” build in this section
(391/200cfm and cut to 62cc)
PRW stainless 1.73 roller rockers and stud girdles
Comp and Manley pushrods
Motorsport “victor” intake re-drilled for a 1050, not ported at this point
1050 dominator carb
14 x 4" air cleaner with K/N xtreme top.
MSD dizzy and 6AL
PRW electric water pump
Canton 6qt street/strip pan for a fox body
Melling HV oil pump and ARP pump shaft.
Hooker super comp LT headers, 2" primaries with 3.5" collectors
Can't wait to see how much she puts down I'm building the set up for my 2000 stang I'm using scj heads and a solid roller cam same pistons as you I'm waiting on machine shop also. Good luck and keep us posted
By my calculations my car will be 2965lbs with the driver. I'm going to weigh it this spring.
I just built a 472 with flat tops and .015 in the hole .720 comp solid roller 268/[email protected] out of the box eddy RPM's and a 1050 dommy, 8" converter w/glide and 430 gears in a 3650LB Cyclone and its been [email protected] and [email protected] so if your car is lighter than 3650 it will go into the 9"s pretty easy, I will keep reading so let us know when you get there, good luck
Thats near perfect hook up......nice going any pics?
Going by the moroso calculator,IMO is a good guide.........your making 610 real HP at the fly. Nice build Butterbean.
Bigrigtech you will be easy mid to high 9's.
I guess time will tell what it will run and if it will hook well enough to go in the 9's.
1 - 7 of 7 Posts
