iam going back to a small block so my big block is for sale
it is a stock block .060 over stock crank 0 balance eagle h beam rods probe piston the block is o ringed and the mains were bushed with arp studs and dss main support
the heads are tfs street heats the old ones ported i have flow # they flow 370 in. 228ex with out a pipe at .700
lunati cam .699in .727ex 264 274 @50 soild roller
comp lifters
comp pro magnum rockers
3/8 push rods
victor 460 intake ported with a nx fogger plummed in
1100 pro systems carb
msd dist
trick flow valve covers
ele. water pump
accufab headers 21/8 x31/2 collectors
motor mounts for a mustang
the oil pan is a old boat pan cut to fit a stang it holds 10qts of oil
jw wheel flex plate
fluid damp. balancer
jw bel to a glide
everything needed to put in a mustang turn key 8500 obo
comes with everything but the vac pump coil and regs.
comp lifters
3/8 push rods
msd dist
ele. water pump
jw wheel flex plate
jw bel to a glide
DO YOU NEED ANY SBF PARTS
