1 - 14 of 14 Posts
477 short block, Trw .060 L2443n pistons, h beam rods, stock crank, new rod bearings, new main bearings, new oil pump, roller timing chain, Lunati camshaft 61605 .582/600, 241/[email protected], 284/292 advertised duration. $900
Procomp heads ported, new never assembled, comp cams roller tip rockers, comp cams magnum push rods, studs, guide plates, PBM intake and exhaust valves 2.25, 1.9x intake new, exhaust used like new fresh ground, just add springs and retainers. $1050
# PC3005-460-0606-0497, push rods #7651
BBF Aluminum motor plate $75
All parts located in Poplar Bluff, MO Prices are plus shipping. email [email protected]
http://i2.photobucket.com/albums/y32/snoopstang
/687689939_photobucket_37437_.jpg
sorry $75 on the plate plus shipping.
edited the ad added head and push rod #'s.. still forsale.... lets move this stuff...
yes, short block is.... just add pan, heads, ect..
heads only are sold.. block should work with heads.. not sure about your cc's would have good compression..
Discussion Starter #12
captain I am trying to verify they will work.... Most say yes...
Wondering if my stock d3ve will work with the cam and valves so nothing messes up..
If you still have it when I get $900 I may contact you...cause I'm trying to figure whether to fix my stock 460 or go bigger..
1 - 14 of 14 Posts
