492 Ford Stroke Roller motor has
Edelbrock Victor 460 intake 4500 flange RPM Rang 3500-8000 rpm’s has a 4500 BILLET Dominator #555-15466 flange spacer plate that goes with it.
NEW Edelbrock Ford Motor Sports Valve Covers HAVE NOT BEEN INSTALLED.
172 Roller Rockers
DOVE-C NEW REWORKED HEADS
NEW 4340 BAL. CRANKSHAFT RATED AT 1500 HP FROM CRANKSHAFT SPECIALIST.
NEW H-BEAM RODS RATED AT 900 HP
MANOLA PISTONS
NEW ELDELBROCK TIMING GEARS
NEW LUNATI CAMSHAFT LOBE LIFT INT.355 EXH.360, VALVE LIFT INT. 615 EXH. 622, ADV. DUR. INT. 295 EXH305,
.050 DUR. INT. 245 EXF255, LASH INT. 000 EXH. 000, LOBE CENTER INT. 106 EXH 114
TIMING .050, BTC 17, ABC 49, BBC 62, ATC 14
CUSTOM MADE OIL PAN DOUBLE SUMP
NEW OIL PUMP AND PICK-UP
THE MOTOR IS $8000.00 OBO MAY DO SOME TRADE LET ME KNOW WHAT YOU GOT. THANKS FOR LOOKING
I ALSO (HAVE NEW NEVER INSTALED) EVERYTHING TO PUT IT IN A FOX BODY MUSTANG (SOLD SEPREATE.) HOOKER 2IN. TUBE HEADERS,MOTOR MOUNTS,DIST.,IGN.BOX,COIL,CUT TO FIT WIRES,Holley 850 double pumper used. MAYBE OTHER STUFF I CAN’T THINK OF NOW.
IF YOU WANT THE TOTAL PACKAGE IT WILL BE $10,000.
I HAVE ALOT OF OTHER STUFF FOR SALE AS WELL. WAYNE 731-376-1559
