Status
Not open for further replies.
1 - 14 of 14 Posts
Thank You for the compliments, I am very proud of this combo but figured with the intelligent people on this board they might be able to help me find a few more ponies.
Banned
Nice Build
lghting94 said:
Just thought I would share some info/numbers on my engine:
Dove-A 2-bolt block
DOOE-R Heads ported and pollished (dont know numbers here)
Stock crank restroked to 4 inch
GRP 6.800 aluminum Rods
Custom Ross 14.5 to 1 pistons
Custom Cam Research solid roller cam 285/295 advertised duration 775 lift (I think)
Victor 4500 intake
1050 dominator (old style)
Dyno Results:
RPM TQ HP
4900 622 582
5000 620 589
5100 618 597
5200 616 607
5300 615 618
5400 615 629
5500 616 642
5600 617 655
5700 618 667
5800 619 681
5900 621 694
6000 621 707
6100 620 717
6200 620 728
6300 618 738
6400 615 747
6500 611 753
6600 606 758
6700 598 760
6800 588 758
6900 576 754
7000 562 746
I know this isn't as impressive as several builds on here but I am proud of what I built. Dont beat me up to much but any suggestions on things I can improve on this combo?
Very nice. Real good power on 495 inches and Iron heads.
Gary Blair,
Gary,
I guess the special dyno carb and headers don't apply to cast scj engines , only TFS Streets :lol:
Lghning94,
You did a good job, nice numbers. old school Fords still get it done. :wink:
Thanks again guys I appreciate all the compliments. The Iron heads are required in my class otherwise i wouldve went with aluminum heads(would've been much cheaper also).
Are those numbers from the dyno with the headers you intend to run?
It seems they might be a little long simply judging by the torque curve numbers.
Good combination though...!
Discussion Starter #12
No that was with the dyno headers. Can you explain this? I want to get custom headers built so more knowledge would help.
I believe longer header tubes (before they reach the collector) will create more back-pressure resulting in more torque. I think its minimal amounts though.
Some one correct me if im wrong...
Better late than never. I didn't see this post before. :D
Getting that last 40 hp is the most expensive.
An 1150 Quick Fuel from Lem done up for your combo will help.
Send your intake and heads to Bret Powell, PFC Engines, to get them dialed in and working together. It will take his expertise to find those last cfms to get the job done.
Just in case you have a high dome: Having a dome no higher than .100 and shaving the heads to 68cc will get you about 14 to 1. The lower dome helps make more power than a tall dome.
Ask Bret about the cam and headers. ;)
Hope that helps,
Dave
1 - 14 of 14 Posts
Status
