Im thinking on another build so I need to sell my 501 first. Please send me a email at [email protected] if your interested. thanks
The block is out of a 78 rollback truck D9TE -AB.
Hot tanked , crack checked, bored .030 over and honed for moly. Brass freeze plugs installed and decked .020 to get the block squared up and compression where I needed it. Entire assemble balanced and clearenced. Eagle cast steel crank 4.14 and Eagle H-beam rods 6.7.
JE/SRP 28 cc dish forged pistons. Assembly balanced . Total seal rings. Clevlite main and rod bearings and cam bearings are Fed Mogual. Arp head studs already installed. PME stud girdle with a good bit of maching to clear the oilpump. This engine is still on the stand and has been stored in my house. With my set of TFS heads with 74 cc chambers , compression should be around 10.2 - 1 . Engine will make about 650 hp est. with the right cam on pump gas. Asking $3900.00 for the shortblock.Other parts may be available but must sell short block first.
Discussion Starter #2
bump
bump
still have engine.
