501 BBF
501 BBF shortblock only.
Was assembled at morans shop . Was around 13 to 1 with the old cobra jet heads on it . .727 lift solid roller cam & lifters. Eagle stroker kit with L19 rod bolts,H-beam rods .030 over je pistons Trick flow girdle Block hard blocked with screw in plugs. block has oil restrictor kit and been glyptol coated completely inside (oil mod by LSM) Alum motorsport dampner. Eagle crank, eagle internals beam rods, New bearings and rings Moroso fox oil pan and pick up Motor sport oil pump Billet motorsport timing set Main studs
3200.00 OBO
Moroso electric waterpump 175.00 http://www.summitracing.com/parts/MOR-63595/
Shane 734 660 3837
located south of Detoit
