1 - 16 of 16 Posts
501 BBF shortblock only.
Was assembled at morans shop .
Was around 13 to 1 with the old cobra jet heads on it .
.727 lift solid roller cam
Eagle stroker kit with L19 rod bolts
.030 over je pistons
Trick flow girdle
Block hard blocked with screw in plugs.
block has oil restrictor kit and been glyptol coated completely inside (oil mod by LSM)
Alum motorsport dampner
CSI flex plate
New bearings and rings
Moroso fox oil pan and pick up
Motor sport oil pump
Billet motorsport timing set
Main studs
3200.00
Moroso electric waterpump 175.00
skinny kid motor plate and mid plate 200.00
msd dizzy 140.00
All parts in south west michigan
will get pics later tonight
586-255-4845 THANKS , ROB
THANK YOU , ILL SEND THEM OUT HOPEFULLY THIS WEEK IF NOT IT WILL B SATERDAY MORNING AND WILL CALL YOU WITH THE TRACKING NUMBER. THANKS AGAIN , ROB
1 - 16 of 16 Posts
