1 - 20 of 54 Posts
Thanks D,
Brandons engine actually made more power per cubic inch than my 557 with the headers we are going to run, with less compression and cam :wink:
Blake
Thanks D. Can I be on the P-51 team since my heads flow pretty close to p-51 #'s?
It will be an honor to have you put P-51 Street Doggs under your signature
welcome to the family!
BB94STANG said:
Car is a 94 [email protected] with a C6 and a 4-link rear. It would run 6.75-6.8o's with a 500 horse 466 and always 60' pretty good for what it had in it. Usually in the 1.38-40 range. I'ts all good.....Damon's going to send me some diapers to use at The Bash!!
how did you get that 94 to 3000 pnds , my 95 is 3344 ,
Discussion Starter #12
It has a tube front chassis. I'm currently stripping my interior trying to get out even more weight.
Discussion Starter #14
We all know Damon can really set up a car to wheelie :wink:
Discussion Starter #16
Finally getting to the track this weekend-if the weather holds out. After the engine was done I gutted the car and rewired it, raised the tranny tunnel, put in a new return style fuel system, put in a front motor plate, made a fan shroud and fabbed an aluminum dash plus LOTS of other little things. I'm hoping for some 6.20's in the heat and hoping not to pull a Damon :shock:
1 - 20 of 54 Posts
