1 - 3 of 3 Posts
FORD 501 STROKER MOTOR $2,000 (plus freight charges via UPS Freight) Call (912)920-6687
This is a standard 2-bolt main 385-series Ford Big Block (370, 429, 460, and 514). The block is a D1VE-6015-AA casting. It has been inspected, cleaned, magna-fluxed, and pressure tested. It has been bored 0.030 over stock, 0.020 taken off the deck, and honed 30°. The block was prepped and painted with Black VHT High-Temperature Engine Enamel.
CRANK SHAFT
Eagle Specialty Products (PN: 104604140) (Cost $278.67)
· Internally balanced
· Cast steel
· Uses OE bearings
Stroke 4.140
Rod Length 6.700
Bob Weight 2350 grams
Rod Journal 2.200
Main Journal 3.000
PISTONS
Sportsman Racing Products (PN: 154166) (Cost $598.99)
· Ford Big Block Inverted Dome Series
· 4032 low expansion, high silicone aluminum alloy, heat treated to SRP specifications
· Pistons are cut for SCJ Heads
· CNC machined ring grooves accept 1/16, 1/16, 3/16 rings
· JE Pistons Straight Wall Wrist Pins: .990 x 2.930 x .150
· Total Seal High Performance Piston Rings
Bore 4.390 (.030 over)
Stroke 4.140
Rod Length 6.700
Compression Distance 1.520
Piston Weight 620 grams
Inverted Dome -28cc
Compression Ratio w/Heads
72 cc Chamber 9.9:1
80 cc Chamber 9.5:1
84 cc Chamber 8.9:1
CONNECTING RODS
Eagle Specialty Products (PN: CRS-6700-3D) (Cost $466.67)
· "ESP" H-Beam Connecting Rod
· Standard Forged 4340 Steel
· ARP 8740 7/16" fasteners
Length 6.700
Rod Journal 2.200
Pin Size .990
Thickness above Pin .220
Weight 815 grams
CAMSHAFT
COMP Cams (PN: 34-341-4) (Cost $129.95)
· 282S Solid Magnum
· This cam features a broad power curve and torque range with a mild rough idle.
· Double Roller Timing Chain
RPM Range 2000-6000
Duration Int/Exh 236 @ .050
Valve Lift .570 with 1.73" rockers
MAIN BEARINGS
Clevite 77 Performance (PN: MS-1039 V) (Cost $61.95)
CONNECTING ROD BEARINGS
Clevite 77 Performance (PN: CB-743 H) (Cost $88.00)
FASTENERS
Automotive Racing Products (PN:155-5402) (Cost $59.95)
For pictures go to: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=260414200569
The motor is in Pooler, GA. It is listed on other sites, including eBay. The first contact will be honored, whether it is from this forum or not.
1 - 3 of 3 Posts
