1 - 10 of 10 Posts
I need a little help.My 502 has 11.7 to 1 compression, ported dove-c heads, a .713 lift roller 274/284 by crane,750 holley.This set up with 30 degrees of total timing and a powerglide with a converter that will stall around 5300,went [email protected] shifting at 6000 with the 5.67 gears going through the 660 mark at 6200 rpms.I changed the gears to a 4.56 and slowed car a little, maybe,I did not get enough passes to tell.It ran a [email protected] the first pass and shelled the rearend after I turned the 2step up from 3200 to 3800.The car is a 91 Thunderbird ORSCA 7.00 car that weighs 3300 pounds.I have always run small blocks, and my last 347 would run within 2 tenths of this motor what do some of you big block people think I need to change,we will probaly do more bracket racing this year. I think that the way this motor revs and sounds I am sure there is some more here.I need to decide about a new carrier and gear set?NO MORE SMALL BLOCKS!!!!!
D
Guest
1st thing I see is the Carb is way small, may want a victor and a 1050.... and timing looks a little low for a dove headed motor, Maybe 34-36 would be more in the ball park?
I have the carb coming,the car has 33-10.5 hoosier tires,what about the gears.I'll try the timing change. thanks ..... Chuck
Banned
Chuck bring your total timeing up to about 36 to 38 and put on a 1050 and a victor and let that thing breath... if you are running 1/8 mile 4.56 if 1/4 mile put 4.10 or 3.90 and use that BBF torque shift that thing up around 6700 and see if it picks up
Randy
Well, two people that agree on this,must be geting close.I will test Sunday afternoon and let you know how it goes.thanks
Sharp looking Bird you have there. Lokks bada*% with those meats on the back.
Don't see too many of that style Bird.
D
Guest
I agree with cougar ,You have way to much gear for a BBF.
3.89-4.10 for the 1/4 and 4.56-4.88 for the 1/8
May want to consider talking with your convertor Mfg / Shop too. Could probably use a tune-up / restall, If that convertor was for a small block it may be way too loose.
I put the 4.88 gear in the bird,run it in on the stands,I heard a noise.I did not think anything about it.When I let the car down I tried the trans brake as I was afraid the trans case might be cracked some where I could not see,the case was fine,the converter is shot.I build a dozen or so powerglides a year for friends and racers.This converter was built just for my index racing,it might need to be different know.How much stall do you like in a heavy car(race only).WHAT NEXT???Chuck
I would order a "custom " stall. It would be around 1200 rpm LESS than your shift point for a glide.
1 - 10 of 10 Posts
