1970 DOVE BLOCK, SCAT CRANK, EAGLE H BEAM RODS, FLAT TOP SRP PISTONS, SHORT BLOCK TOGETHER,MATCHING SFI FLYWHEEL AND BALANCER, BOUGHT A BALANCED KIT, WHEN SHOP BUILT ENG. THEY CHECK BAL, VERY SMOOTHE JOB ON IT, NEVER NOS ON IT, FOX BODY TYPE PAN STOCK STYLE FORD MOTORSPORT, CRAN HYD. FLAT TAPPET CAM 583/588 LIFT, DOVE C HEADS, BEEN PORTED WITH 2.25 INTAKE VALVES,10 DEGREE LOGS AND GOOD KEEPERS, ALL REALLY GOOD PARTS, ENG. NEVER RACED IT WAS IN A F100 PICK UP, NEEDS TO BE FRESHEND DUE TO BEING APART, WOULD NEED RINGS AND BEARINGS AND GASKET SET, I HAVE A NEW MELLING OIL PUMP IN BOX AND NEW CRANE ANTI PUMP UP LIFTERS NEW IN SEALED BOX,NEW MSD ELECTRONIC DIST. MOTORSPORT VALVE COVERS, WATER PUMP, REALLY TORQUE ENGINE, ALOT MORE THAN LISTED THAT COMES WITH IT,JUST LIFE IS HEADED IN DIFFERANT DIRECTION AS OF NOW, $ 1600.00 CALL 864-426-6914 ANYTIME THANKS...
