514 ready to drop in and fire. Everything is new RPM intake, old school SCJ heads, mid 70s block, Edelbrock cam n lifters, eagle guts. MSD dizzy starter , alt, pulleys as you see it less carb. Hugh's C6
Need to look back for the comp but it's 9.5 ish. No head work out of the box and on the motor.Compression ratio? Any head work done?
36-1 street n strip is what is says on the invoice.What's the part number on the C6?
Check your PMnew member and joined because I ran across your ad looking for a 460. Is there a way I could contact you to learn more about the engine? Thanks!
