1 - 9 of 9 Posts
514, d1ve block, aluminum stud girdle in bottom with ARP studs, scat crank,eagle H beam rods, srp flat top pistons, moroso oil pan for fox body, roller cam bearings,solid roller comp cam 740/760 with 110 lobe seperation, aluminum cobra jet heads, ported with stud mount rockers and jomar girdle, trick flow track heat 4500 flange intake port matched, 1250 dominator carb. motor has about 20 200 ft passes on it since it was fresh from machine shop in august. runs great, just changing classes for next season and have to change engine size, have numerous pictures i can text/email, call or text anytime 478-973-8879 thanks! located in Macon,ga $7800
1 - 9 of 9 Posts
