1 - 8 of 8 Posts
514 CRATE WITH/SCJ HEADS & Lentech AOD 429/460
Selling D514 crate motor has kaase scj heads bought new from ford motor has never been started. Has canton front sump pan and msd plug wires. 6500.00 located in wi. 920-373-0928
Discussion Starter #2
Lentech AOD 429/460
Lentech AOD trans has sfi 460 bellhousing, full manual valve body(does'nt use cable) deep cast aluminum lentech pan. Lentech torque convertor trans set up for 514 crate motor trans never used. 2500.00 located in wi
Lentec
Would you trade the Lentec for a built C4 with a custom built TSI converter ,JW Ultrabell ,manual valve body ,B&M pan ,an fittings ? The converter is new as well as the tranny being fresh No brake but otherwise very heavily built
No I'm just looking to get out of project, No trades
1 - 8 of 8 Posts
