I have a turn key 514 out of my 79 Mustang complete with C6 transmission for sale.
Its a DOVE block with stock offset ground crank and Eagle rods with JE pistons approx 10:1 CR with Cobra Jet aluminum heads. It has a Comp cams roller cam and lifters with roller rockers and hardened push rods.
Stealth intake with Holley 750cfm carb. Kooks FOX body headers will fit stock crossmember with mounts removed.
TCI street fighter C6 with 2800 stall converter, complete with trans cooler and braided lines.
MSD 6A ignition box.
Holley blue pump with regulator modified by the Carb Shop.
This is a complete engine and transmission which you could drop into a FOX body car and once you provide a fuel source and electric and cooling it would be complete and running.
This is a complete engine and was running when I took it out of my car. Uses a motor plate not regular motor mounts.
I can send pictures if you're interested.
$7500.00 + shipping.
