514 "Fresh Never Fired"
Seasoned de-burred block, Cast Steel 4.140 Stroke Crank, Steel H-Beam 6.8” Rods, ARP rod bolts, Clevite 77 rod bearings, main bearing support kit, oil restrictor kit, reworked chamfered oil passages, 10.8 :1 Speed Pro power forged pistons, Speed Pro Rings, screened and polished lifter valley.
New Super Cobra Jet Aluminum Heads, ARP head bolts, Manley 2.20 intake, 1.76 exhaust valves, molly push rods, Crane 647 lift/258 duration cam, Crane dual valve springs, 1.73 aluminum Milodon roller rockers, guide plates and lock downs, Offenhauser Port-o-Sonic Dominator Manifold, Cloyes double chain, Fluiddampr harmonic balancer, Milodon screened pan, Melling high volume oil pump. The engine also comes with a new Hays balanced aluminum flywheel, 6 bolt pressure plate and super connector clutch.
Everything is new in this engine except for the block and crank, which are sound pieces in excellent condition. Will guarantee this engine is sound and will run hard after proper break-in. Asking $5,500.00. Can arrange shipping. Will consider partial trade for Ford truck/car.
If interested and would like more info and detail photos, please e-mail me at [email protected].
Thanks..
