1 - 9 of 9 Posts
· 515 CI BBF
· A460 block – 4 bolt splayed caps – oringed – 4.61 bore
· CS billet crank – 3.85 stroke – internal balance – 2053 bob weight
· King race bearings – roller cam bearings
· GRP #5001 rods – 6.800 x 2.200 x 0.990 pin
· Trend pins – 2.930 x 0.990 – 0.185 wall
· Diamond pistons – 12 cc dome – build #59656 – nitrous application
· Total seal rings – gold oil rings
· TFS A460 heads – 2.400 titanium intake, 1.900 titanium exhaust
· Heads are prepared by Mike Stark-CFM – flow 452/300 @ .800 lift
· Clark copper 0.051 head gaskets
· Matching TFS single dominator intake – ported by CFM
· Prosystems SV1 – 1400 cfm carburetor
· Cammotion billet cam – 284/301 @ 0.050 – 820/779 lift – on a 112
· Manley nextek springs – doubles – (valvetrain is very easy on springs!!)
· Scorpion 0.120 wall pushrods, scorpion race 1.73 rockers
· Jomar girdle
· Custom 2.25”-2.375” x 4” stainless headers with vibrant mufflers – foxbody
· ATI super damper
· JW – the wheel flex plate
· Peterson external oil pump – wet sump
· Custom aluminum baffled pan – has oil heater/temp sender installed
· Moroso vacuum pump
· CSI waterpump
· MSD crank trigger
· MSD crank trigger style distributor
Motor cranks 235 psi cold, and 225 psi hot.
Compression is 14.5-1
Peak power – est – 1000 hp @ 7600 corrected– current runs calculated 945 hp @ 3200 density altitude
Motor runs are on Klotz 118 race fuel
Current run time – 6 full motor passes, 7 half passes.
$11,000 B/O !!!!!!!!!
Also have ATI glide with a UCC 9" converter
$14,000 B/O for combo!!!!!!!!
Pics here>>>> http://s227.photobucket.com/albums/dd83/feetfirst/25-5%20mustang/
what is the weight of the car on that 8.80 pass? have you sprayed this motor? will it handle a shot of nos?
If he gapped the rings for nitrous and you run good race gas then it should take a good bit of juice ,by looking at his parts-nitrous pistons, good block and crank. It could almost fly on spay,lol
LOL!!!
Rings are gapped 26 top, 28 second.
Weight of the car is 3030 lbs on that run.
whats your best time on motor @ what timing, stall, gear, tire size, what rpms you leaving at, and footbrake or tbraking?
"· CS billet crank – 3.85 stroke – internal balance – 2053 bob weight"
is that crankshaft specialty in Memphis??
1 - 9 of 9 Posts
