1 - 20 of 56 Posts
well i never posted info about my turd so here it goes :
521" stock block filled to bottom of water holes
4.30 steel crank
o-ringed block w/ sce cooper gaskets
wiesco pistons fly cut
12.1 compression
r and r pro aluminum rods
edelbrock cj heads 74cc cnced decked .006-.008
RPM CJ460 Heads
Intake Runner: 340cc
Intake: 2.190”
Exhaust 1.750”
Flow Bench: SF-600
Clay Radius Intake Adaptor
No Pipe on Exhaust
Flowed On 4.400” Bore
2.190” Valve
Intake @ 28”
.200 151
.300 225
.400 277
.500 315
.600 347
.700 364
.800 380
1.750” Valve
Exhaust @ 28”
.200 112
.300 150
.400 179
.500 200
.600 215
.700 223
.800 228
edelbrock victor 460 intake port matched
cam motion custom nitrous cam
cam lobe size in 1.228 ex 1.260
intake dur 269.1
valve lift .76842
exhaust du 279.7
valve lift .72714
lobe sep 112
msd digital 7 w/ crank trigger
hvh super sucker nos plate 100 shot
nos fogger 250 shot --- never used
3300 lbs with driver and nos bottle
3.73 gear
p/g fully rollerized with 1.80
ladder bar suspension
28 x 10.5 x15
4300 tight convertor
trans brake
so at Windy Hollow in KY Temps were in the lower to mid 90's and humidity was high it ran several 5.98 @ 117.5 and a 5.96 @ 116
its been a best of 9.38 @ 144 in the 1/4 before the suspension was giving me problems and that was with running 6.20s now all of this is on the 100 shot --- it usually runs 6.20 - 6.30 on motor and 9.8 - 9.9 on the motor in the 1/4
will keep everyone updated on the 1/4 mile times
http://460ford.com/viewtopic.php?t=30342
added link to evans tech article on head work
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
Thanks for sharing the info with us. Don't see too many guys posting about using Edelbrock heads. Would those be the 61649 heads?
Very impressive.
Nick, Very impressive indeed ! and with Ed Heads to boot ! Are you planning on a head change with a higher flowing head? :twisted:
Russ :shock:
Nick I can see the writing on the wall. You are gonna step up and get a set of them bad azz Pro Comp heads aren't you. :wink: :wink: Dave F. says they rock like nothing else, and would trade anyone straight across for the heads he picked up at the Bash. :lol: 8)
very impressive ....B.T.W. it`s honest info sharing such as this that makes this site the best around. it`s like one big think-tank. everybody
benefits.
hopefully this will more get people to put BBF`S in thier cars instead
of the big chevy`s that are so common by me in the n.j./n.y. area.
I'd sell the E'brocks and get a set of P-51's from Charlie and a cam from Lem. You'll probably have to get the pistons worked for the P-51 chamber and valve layout, but I think you'll pick up some with them.
Discussion Starter #13
No problem Jon ---- but lets compare apples to apples !!!!! Blake has a badass ride but he is @ 3000 lbs im at 3300 --- i belive we should put that in the equation ..... plus he has 36 more cubes --- should i go on ----
im not whining yes his car is faster then mine --- but what if i lost 300 lbs and changed my rear end gear to say 4.11 ---- i would have to think it would be a very impressive race --- motor to motor --- and you guys have to understand this is a nos motor ---- not just a h/c BBF and we just decided to add nos ---- the cam , carb , convertor , gear , heads were all designed around the spray....
i believe that my motor can go up against any one of these guys motors on this board ie: blakes , damons, sherry's etc....
damn Jon you are messing with my emotions now !!! oh by the way Jon thank you for letting me see the light ....
Edelbrocks Rule --- they are not for sale anymore !!!!!
let the comparing begin 8)
Your right Nick, your car is geared and convertered for big spray, I'm not taking anything wawy from it.
I still think Blakes deal with the same converter and gear as you would not really make a difference, that motor is a hoss.
What did you say Jon, ( It's all about the azz and shoes ) :lol:
Blake
D
Guest
Bruno stick with the Eddies...Your car ran great !!
I'd look into putting the car on a diet, Gearing and convertor before you change the heads. (and the 250 hit)
There ya go Nick ! Get a set of the Boss9's and have Charlie rub on them and have Lem grind you a bump stick and YeeeHaaa!! :lol:
Russ 8)
Discussion Starter #20
1 - 20 of 56 Posts
