Got all the bugs out and got a couple clean runs at the track best run 9.35 @ 142mph.
my build was as follows running on 94 octane pump gas
*Ford Motorsports Block
*Old style cobra jet heads
*lunati crank 4340 Forged
*lunati h-beam rods
*probe pistons
*Lunati 9 key timing chain and gears
*Lunati Voodoo rocker
*comp roller lifter
* Comp custom grind Cam
* I started with Milodon pan pn#31484 with rear sump, 3 compartment with baffles but lost oil pressure at about 6000rpm. Ended up with 8 quart front sump pan that I use to run on my 72 mustang with a HV pump
