has anyone had trouble with clearance for this type of build i am using a 6.8 h-beam rod 4.3 stroke crank in a 71 460 block any info on this type of motor would be helpful as i am wanting to build ths engine for my mud truck. Thanks Donny
With the typical steel connecting rods that come in the stroker kits, the Ford 521 combos that use the 4.300" stroke crankshaft have no crankcase clearance issues whatsoever, nor do the 4.500" stroke crankshafts. Often, even the 4.500" stroke cranks don't have clearance issues with some aluminum rods (but not all).has anyone had trouble with clearance for this type of build i am using a 6.8 h-beam rod 4.3 stroke crank in a 71 460 block any info on this type of motor would be helpful as i am wanting to build ths engine for my mud truck. Thanks Donny
