1 - 20 of 35 Posts
Ok I got frustrated with trying to shoe horn this monster in my 69 mustang:mad:. so Im just keeping my cleveland. my loss is your gain. This is what I have.......
1. C9VE-A heads ported.
2. FRPP 521 storker kit using 4.3 crank, Eagle H beam rods, Forged SRP pistons part #150727
3. Ford motorsport VICTOR polished intake
4. Holley 1050 dominator carb
5. Stainlees steel CJ valves
6. Crane cams 1.7 RR part #13744-16 with guide plates
7. Boss 429 hood scoop 5" tall
pretty much everything except the Cam. If intrested make me an offer at [email protected]
FYI, the SRP 150727 pistons are 4.390 bore forged flat tops with a -3cc valve relief. It's spec'ed on the SRP site as a 501ci motor using 4.14 crank with a 6.8 rod and is 1.42 c/h. May want to check the part number again because the math won't add correctly for a 10.3 block with 4.3 stroke crank in any standard ford (6.605, 6.7, 6.8) rod configuration.
1. Deck height 10.3
2. Bore 4.390
3. Stroke 4.3
4. Rod length 6.605
5. CC using C9VE heads 72cc
6. Piston dome -3
7. Pin height 1.420
Equals>>>>>>>>>>
1. Deck clearance 0.125 inches
2. Compression ratio 10.4:1
3. Rod ratio 1.54:1
4. Max rod angle 19 degrees
5. Displacement 520.7
So yes I did my numbers and homework and have this set up!
@Kjett believe me when I say this isn't my first engine build.
Never questioned your engine assembly skills. Just seems a bit low on the compression height than the FRPP 521 kit that Lem Evan's sells and will yield the same compression with a 28cc dish and a better compression height. Not sure you'd want to leave the piston .125 in the hole with a 10.3 deck height. Stock pistons were only .038ish in the hole with a 10.32ish deck height.
The original intent was to let others know what that piston p/n was originally for. ;)
Shouldn't the compression height be 1.54 on those 521 Ford kits? Add up all the numbers and comes to 10.30. Maybe I'm wrong:confused:
Discussion Starter #13
pistons sold. thanks
still have 4.3 crank from ford racing and Eagle H beam rods 6.605.
make offers I need this stuff gone.
Discussion Starter #17
$700 for crank, rods, balancer and sfi flywheel.
$250 for victor intake
$150 for comp cams RR
$300 dominator carb
1 - 20 of 35 Posts
