ENGINE:
528 cu in
stock dive block short filled with main stud girdle
4.30 scat 9000 series crank
eagle 6.8 h beams
custom ross dished pistons
moroso eliminator fox swap pan
herbert solid roller 261, 270 duration .050 .710, .714 lift
Ported dove heads with 2.19, 1.76 valves, Intake runners matched to pas. car size. Exhaust runners are ported very aggresively.
Edelbrock victor intake with one inch spacer, extensive plenum porting. The spacer is pinned to the intake and ported. Runners are matched to dove heads.
1000 CFM holley hp carb.
Hooker fox swap headers with stainless merged collectors
msd dist.
TRANSMISSION:
stock case powerglide with stock pump
1.80 straight cut planetary set
Pro tree trans brake valve body
billet hub
PTC 9 inch converter 4500 stall
moser 9" rear
35 spline axles spool 3.70 gear
Car is a fox mustang hatchback weighs 3280 with me in it. It is mini tubbed with ladder bars 28x13.50 ET Street tires. I built this car with a goal of 10 teens and reached that goal last night.
Best run so far is 10.14 @ 133.75 with 1.461 60 footer,6.51 1/8 mile
Thanks for looking, engine will be for sale soon if anyone is interested.
Nice run and nicw car.
I have a question with the weight of the car would it be faster with a 3 speed or not? ALso what's it pulling for RPMS at the traps.
I reason I'm asking is I building a Fox body that will be very close to your setup, I'll have smaller cubes but Blue Thunder heads and Turbo400.
I shift at 5600 and it goes through the traps at 6300. I'm not sure if it would be faster with a 3 speed. I know it would benefit from a 3.90 or 4.10 gear it leaves soft. I'm not going to change gearing because i'm building a 598 wth a460 heads for next year and that combo will like the high gear.
