1 - 8 of 8 Posts
533 pump gas BBF Open to offers
Listing the engine separate from my car. Going to see about keeping the car and converting it.
D1VE block. Machine work done by Rickman Auto parts in Rickman Tn
Assembled by a local builder Stacey Cash
Been together approx 6 yrs. Little run time due to lack of time after was built.
Scat Forged bottom end kit, with Forged H-beam rods and JE dish pistons. 9:8.1 comp
Neutral balanced
Summit SFI balancer with billet 2 groove pulley and alumn spacer sleeve
Moroso electric water pump
FRPP 90* oil filter adapter
SCJ-B heads. Changed springs (Pac Racing) last winter, along with retainers, keepers, custom ground Comp cam from Lem Evans
Comp Cams solid roller Lift Int/Exh .683/.683 Duration .050 int 260 exh 268 110 lobe seperation. Specs are for 108 installed centerline.
Herbert solid roller bar lifters
3/8" pushrods manly and trickflow
Harland Sharp 1.73 rockers clearanced slightly for the retainer.
Jomar stud girdle
Canton deep front sump oil pan with windage tray and pickup
Melling HV pump
CLoyes adjustable timing set.
Mafia intake.
New last year MSD distributor
Moroso wires.
also have Hitachi starter if wanted.
This is complete running engine.
Located Albany Ky can call or text 606-306-5260
Asking $8000 OBO buy responsible for pickup or will try and work out shipping. I have not shipped an engine before.
Would consider a Coyote Block as partial trade to build on
Or T56 magnum trans setup.
1 - 8 of 8 Posts
