1 - 13 of 13 Posts
533 pump gas BBF turn key
D1VE block. *Machine work done by Rickman Auto parts in Rickman Tn
Assembled by a local builder Stacey Cash
Been together approx 6 yrs. Little run time due to lack of time after was built.
Scat Forged bottom end kit, with Forged H-beam rods and JE dish pistons. *9:8.1 comp
Neutral balanced
Summit SFI balancer with billet 2 groove pulley and alumn spacer sleeve
Moroso electric water pump
FRPP 90* oil filter adapter
SCJ-B heads. Changed springs last winter, along with retainers, *keepers, custom ground Comp cam from Lem Evans
Comp Cams solid roller Lift Int/Exh .683/.683 Duration .050 int 260 exh 268 *110 lobe seperation. Specs are for 108 installed centerline.
Herbert solid roller bar lifters
3/8" pushrods manly and trickflow
Harland Sharp 1.73 rockers clearanced slightly for the retainer.
Jomar stud girdle
Canton deep front sump oil pan wit windage tray and pickup
Melling HV pump
CLoyes adjustable timing set. *
Mafia intake.
New last year MSD distributor
Moroso wires.
also have Hitachi starter if wanted.
This is complete running engine.
Located Albany ky *can call or text 606-306-5260
$7800 turn key with Hitachi starter
$10k with powerglide trans
I have not had the engine on the dyno. Was built with specs like the FRPP crate engine 514. But went 533ci. Me not being much of a drag racer and with the original cam (which was not enough in this engine according to Lem) car ran 6.20's in 1/8. Have not had the car to the track since installed the new Comp Cam that Lem spec'd for me along with the mafia intake.
1970 mustang tube chassis ladder bar car.
http://www.460ford.com/forum/41-auction-block/219394-1970-mustang-fastback.html
Thanks,
Greene
$8200 turn key carb to pan with hitachi starter
$10k with power glide trans package deal
powerglide is 1.98 planetary, roller tail shaft, pro tree brake, deep pan, JW ultra bell and wheel flewplate, boss hogg converter.
Discussion Starter #12 (Edited)
All Pm's replied to.
$7800 carb to pan. (turn Key)
I will keep from flex plate back. You get water pump, starter, plugs, wires, 90* oil filter adapter, all. I will keep my radiator hoses and filler neck.
Buy responsible for pickup at this price.
1 - 13 of 13 Posts
