1 - 9 of 9 Posts
First off thanks Paul Kane for all the help and block work, prep and a awesome oil pump
This a D1Ve block std 2 bolt 4.440 bore
Ford Motorsports 4.3 crank
Custome lw Probe dish pistons
PPE 6.605 H-beam rods ARP bolts
Victor intake Dom flange
MSD ign.
D3 heads milled .100 80cc comb chamber, 2.20 int valve 1.80 exh valve, hardened seats, bronze guides (11/32), milled valve serface for 1.75 springs, ARP rocker studs installed, Manley severe duty valves, intake flowed 360cfm @.700 Has a 290cc intake ported (super cobra jet gasket matched) These heads where originally built for a 557 bbf with a .722 solid roller then my buddy bought some blue thunder heads I got them for a draw through turbo build that destroyed itself on the dyno so figured they'd be perfect for my pump gas 533
.640 int 240 @ 50* / .640 exh 240 @ 50* 110 lc solid roller cam (it's what I have till straub works his magic)
850hp proform carb (looking for a 1000-1050cfm 4150)
Motor nets 10.1-1 comp
Motor will be used a my pump gas (marine) cruiser motor
STRAUB picks his cams using a dartboard....lol, but seriously his the man for a custom cam!
Can't wait to get mine for the p-51 headed 545.
Cheers, Bob
He's done several cams for my friends 500ci + bbf and all have been spot on and make such usable hp and tq, the biggest problem with a jetboat motor is making enough power in front of the power absorbing curve of the impeller your using. Straub really seems to have a great understanding of this. This motor will be turning a AA impeller but I'm installing a IS plate system 100-200 tune, this will be for those sundown hot laps on the river
Any hp guesses? I'm hoping for 650 under 6000rpm due to my hp absorbed by my Impeller peak tq before 4500 rpm
So this motor turned into a 557 build due to a prepped 4.440 bore block and no availability of the ford motor sports 4.3 crank with 2.5 rods so I will be updating shortly
Discussion Starter #7 (Edited)
Motor is back on track and finished thanks to Paul Kane for getting me a RARE internally balanced Ford motor sports 4.3 stroke 2.5 rod crank, crank has about 8 pieces of Mallory metal installed. Crank weighed 74lbs, not bad.
Using the ford motor sports 521 roller cam since I need the power band to be under 6000 rpm. Installing a ford motorsports (victor style) intake and running a AED 1000cfm/4150 carb (for mileage).
Whats the lift/dur on that 521 FMS cam?
I went with the Kaase/comp cams.
1 - 9 of 9 Posts
