1.i have a 540 short block assembled and ready for heads its a dove a studded 4 bolt main block punched .30 over scat crank shaft BME aluminum rods probe forged flat top pistions that are fly cut for cobra jet or a 460 heads high flow oil pmump stud gridle and windage tray has a 750 lift full roller cam drouble roller timing chain and balancer big truck oil pan was in a pulling truck run it is fresh was tore down and freshened this past fall asking $4000
2. weiand stealth intake 8012 model $120
3.RCI transmission scatter blanket $50
4. scat sfi approved flex plate $100
5. brand new set of SEC head gasket $100 {these are $60 each new from summit}
6.holley blue electric fuel pump $75
7.holley mechanical fuel pump rotating base 110 gph $75
8.electric fan 4500 cfm stock ford $50
9. c6 4x4 tranny set up for pulling reverse manual vavle body red alto clucthes servo up grade has aluminum 4407 t-case to go with it $800
my cell no. is 724-730-3662 im located on the ohio pa line near youngstown
More info on:
please.
its from a mid 90's lincoln its the 2 speed fan i had it on a 4 core rad on my pulling truck you could stand in front of the truck and feel it draw air thru it also has the plug with about 6 inches of wire get me an e-mail and i can send you pics
pm sent. Also how much $$$?
Thanks for the pics.
What are you wanting for it?
