It depends on the overall engine combination. You need to provide a lot more detail on all the components being put together.i have a cam with a lift of 543 in and .574ex. wat all needs to be done to the engine to make this cam run without any problems??
stock everything that came on a 74 licoln continental 460It depends on the overall engine combination. You need to provide a lot more detail on all the components being put together.
Paul
so what would you do to have this cam running goodACTUAL valve lift in that engine MUST be measured and not the written theoretical measurement extrapolated from the lobe lift taken for granted.
You want to build an engine around a cam? Most of us spec the cam for the engine that we want to build. What are the duration specs? Assuming they are around 235 at .050so what would you do to have this cam running good
as mentioned before you need more compression (heads or pistons), better induction (intake and carb), and headers.
If I had a 1974 motor and wanted to make it run without major changes that cam wouldnt be used.
Assuming that the short block is to remain untouched.
Exchange the D3 heads for C8, C9, or D0VE's to bump up the compression.
The cam would be max. duration at 225 dur and .525 lift, must have the springs to match.
A new roller chain with the cam dialed in.
Dual plane manifold with a 750-850 Holley.
There are many more variables that should be evaluated to make decisions based upon vehicle specs. and intended use that will tailor your selections.
Dave
and the vehicle is a 82 ford f100 1/2 ton.You want to build an engine around a cam? Most of us spec the cam for the engine that we want to build. What are the duration specs? Assuming they are around 235 at .050
Dave
wats mixmatch about it? the gear drive?I want to suggest ya state your goals and what car ya want to put this in. It seems that ya got some mismatched parts in mind.
Then get one of my "custom" street rod camshafts tailored to exactly what you want...i wanted the choppy lope sound and muscle without having to go thru the whole motor... but pretty much with this cam i'll have to rebuild? correct
so more duration, lobe seperation or wat?Lift doesn't make the sound you are wanting. Duration and lobe separation has more to do with it. Still, it makes a crappy engine without the comp recommended for the cam.
I think you fail to see the guys point ... he wants to leave the heads on and not do rebuilding of the short block.Personally I'ed get me a Ford C-460 cam, more compression,put a decient valve train in it, cut the guides both for height and size, put on good seals the check the piston to valve clearance, probably have to notch the pistons. A good manifold and carb. By then you will have an engine that will be set up properly to do what you want, and then sell that cam!!
so with the custom grind cam you carry the heads will have to be machined but wont have to touch the short block???I think you fail to see the guys point ... he wants to leave the heads on and not do rebuilding of the short block.
He has his own ideas so, he must know kinda what works. Why he is asking for advice and then simply dismissing it as irrelevant, is beyond me. (tongue firmly planted in cheek).
"Good judgement comes from experience and EXPERIENCE, well ... that comes from bad judgement" - Ben Franklin
Put the cam & new lifters in the engine with a "straight-up" timing set and do a "break-in" ... nothing needs to be machined.so with the custom grind cam you carry the heads will have to be machined but wont have to touch the short block???
