1 - 3 of 3 Posts
will trade for HIGH END sbf motors (only) turbo,charger,na,nitrous
also trade for trucks,boats,bikes,or whatever
$10k
scat billet crank
grp rods
cp pistons
max ported kasse cj head (very nice job)
ported and welded on ports by pushrod
max ported victor intake (will fit 2100cfm tb)
setup for 2 sets of ann nozzles
comp cams red rockers and jomar girdles
hellfire rings
ati balancer
mandrel
motorsports covers with welded fill bung and vacuum port
front and mid plate
headers for fox
milodon pan
csr water pump
msd pro billet and msd wires
motor is fresh and ready to go
has new not even installed yet danny b billet belt drive
new headers
kasse oil pump with 1 pass
here are cam specs
also have a complete glide with bradco bolt together 9 5/8 and jw bell for $2k to buyer
RE. CAM SPECS
Serial # F 6823-05 Spec Card# 08474505
Part # 34-000-9 CAMSHAFT, FF FORD 429-460 ROLLER
Core C34-9E CAMSHAFT BLANK, FF 429-460 STEEL-BIG BRG
Grind # FF 1718R /1209R SR115.0
DURATION @ .050 INTAKE 285 ROCKER ARM RATIO
VALVE ADJ INTAKE .022 DURATION @ .050 EXHAUST 308 INTAKE 1.70
VALVE ADJ EXHAUST .022 LOBE LIFT INTAKE .4710 EXHAUST 1.70
VALVE LIFT INTAKE .800 LOBE LIFT EXHAUST .4610
VALVE LIFT EXHAUST .783 LOBE SEPARATION 115.0
DURATION .020 INTAKE C/L 115.0
TAPPET LIFT INTAKE 318 CAM ADVANCE 0
TAPPET LIFT EXHAUST 348 HYDRAULIC
VALVE TIMING .050 OVERHEAD CAM N
VALVE OPEN INTAKE 27 JOURNAL DIAMETER STD 2.224
VALVE OPEN EXHAUST 89 RECOMMENDED VALVE SPRINGS
VALVE CLOSED INTAKE 77 DEPARTMENT P
VALVE CLOSED EXHAUST 39 SPC INSTR FOR CUSTOMER
RUSTANG CAMSHAFT
1 - 3 of 3 Posts
