If you are to expect an answer here in the future, the ALL CAPS post has got to go.
I have seen engines with "zero" gap rings consum oil and too much piston to wall clearance or anything causing excessive "piston rock" do the same; (especially rock at the BOTTOM of the cylinder).
Not enough to foul spark plugs or even show signs in the combustion chamber - you're talking about a THIMBLE full every five miles or so and that is virtually undetectable.
EDIT: Use the Mr. Gasket intake gaskets or the Fel-Pro with the metal enforcement sandwich; (not the regular black and blue Fel-Pro high performance gaskets).
