1 - 12 of 12 Posts
I've got a few questions but am not a serious buyer unless I could sell the
wife (don't have a first born yet :wink: ). Is it a fresh rebuild, if not how
many passes? Do you have any flow numbers for the heads? Fully ported,
I imagine it must have a small cam to make 845hp w/ C heads. What rpm
does it peak at? I know this isn't the engine build-up section, but it might
help you sell it. Thanks, Kevin
Never been installed in car... Its 95% brand new only dyno time on it.
The Intake flows upper 400CFM Exhaust mid 300CFM @ mid 700 Lift …
With 13.1 13.5 & bigger Cam it will make over 1100HP …
BTW... this engine is built by one of the fastest car engine builders in the country ... http://www.fasttimesmotorworks.com/ ...
For more detaile heres my # 847 678 3000 or E-mail [email protected] ... Thanks Nayel
WHAT IT NEEDS IS
14.5 PISTON'S
.900 ROLLER TO MACH THE NEW CONBO
TRICK FLOW TUNNEL RAM MAXED PORTED w/PORTED ADPTORS TO FIT C HEADS
A PAIR OF 1250 or BIGER MAX FLOW CARBS BUILT FOR THE CONBO
HEADS RE MAXED PORTED FOR BEST FLOW ARUUND .900 LIFT MAYBE A SPLIT LIFT
A NICE SET OF STEP HEADERS WITH MURGED COLLECTORS CUSTOM BUILT TO MOTOR AND FIRING ORDER IF USING A SPLIT LIFT CAM
AND
EVERY 1 ON HERE TO TAKE UP A COLLECTION & BUY ITIS MOTOR FOR ME AFTER ALL THAT IS DONE
I WILL PUT EVERY BODYS
NAME ON MY CAR
THINK ABOUT
PLEASE
1 - 12 of 12 Posts
