1 - 10 of 10 Posts
Has anyone used this from Dynoflo Performance Auto Works.557 rotating kit,RPM crank,Probe SRS,Eagle 4340 3D H-beam rods 6.7 or 6.8 with ARP cap screws.Balancing for 100.00.This sells for 1399.00. :?: Thanks steve
Thanks RyanJ,i have found that a 577 build can be done for almost for the same amount as a good 466.There are lots of dif kits to chose from and i will look at them close as well talk by phone untill i get the wright one.Good parts cost but make dependable power. :!:
You have to have a aftermarket block to go 577. 557 is as big as you can go w/stock block,and it should be sonic tested.Rick
557
BBFMavrick, your wight. I ment to say 557.Going crazy here,trying to build a car and engine at the same time. Have you used a D-D motor plate kit before or know any one that has. At this time it is what i wont to use. :?: :?: Thanks Steve
YOU DONT NEED A AFTERMARKET BLOCK FIND A DOVE-A BLOCK . A 532 IS THE SAME BORE AS A 557 A 4.440 JUST A 4.3 CRANK 6.7 ROD VS. 4.5 CRANK 6.8 ROD :twisted: :twisted: :twisted:
WHat BBF stroker is the best choice for weekend toy?
looking at purchasing a short block from
http://www.racingjunk.com/post/432380/Big-Block-Ford-557-Shortblock-Eagle-bbf-forge.html
i need to know who can grind me a solid flat tappet for it to make over 650HP
this is going in a 91GT fox body
8 point cage, sub frame connectors, 90/10`s up front 50/50`s out back
10gal cell -8an line to regulator with black pump but the black pump is overheating for some reason so im going to use a aeromotive a1000 pump or a good mechanical if they make one for a BBF?
need advice on what bore and stroke i want 557 is ther eany problem with that?
also this car is a garagae queen comes out a few times a year to do some smoky burnouts and to go to local car cruises/shows and once in a blue moon we may take it to the track any advice on this build is appreciated
557 now 532
Well i ran across a eagle 532 rotating assembly already balanced, 6.8 h-beam,4.30 steel crank, probe 10663-80. Saveing some cash for some P-51s and mybe i'll slip this thing together over the winter. Have been getting most of my parts from web members and still have a long way to go. thanks steve
1 - 10 of 10 Posts
