New low price guys. 9000. I can't go much lower than this, losing enough as it is!
http://www.racingjunk.com/post/1370803/557-BBF-over-800hp-.html
Here is the build sheet, was built by Ford Performance Solutions in California. Engine only has 4 dyno runs!!
CCR6.800H 6.800" 4340 CHROMOLY H-BEAM RODS (2.200" JOURNAL)
RS10133-5 4.443 BORE 1/16 1/16 3/16 DURAMOLY RING SET
30-32 Ross custom pistons 429-460 4.36-4.42 Dish
MG460 BBF 460 MAIN SUPPORT
PORT INT2 INTAKE MANIFOLD PORT STAGE
CUSTOM SOLID ROLLER CAMSHAFT
P162A 351C-460 1.73 X 7/16 STUD MNT ALUMINUM ROLLER ROCKERS
P972 460-A FORD MOTORSPORT PRO ROCKER STUD GIRDLES (SET)
VC460/LOGO BBF Polished logo 429-460 tall
PRP10401 holley dom braided fuel log
PRB10243 429-460 BAl spacer w/o wt
TFS5440T80 TFS a HEAD COMPLETE SOLID ROLL 1.00 ER 2.300 intake valve
CNC PORT CNC Porting
ROLOS5315H 429-460 hp pan gasket blue
DET14019 460 ford timing cover set
DB2520 ALUM DANNY BEE 460 BELT DRIVE
TFS5440011 A-460 4BRL single intake
CC836-16 COMP CAMS BBF HI-TECH SOLID ROLLER LIFTERS (429-460)
SB557ROSS BBF 557 custom ross short blk
CRA4.500/S 4.500 stroke steel forged
T crank
VG460 valley girdle pro 460
HARD BLK HARD BLOCK FILL CYLINDERS
MSN distributor & crank trigger kit
MOR22642 4 vane enhanced vac pump
Custom oil Pan
HOL80556 1150 annular soft 3 circuit
MOR23520 V belt 2.500" for vac
STE6572 3/4 wide spacer dry sump
STE6552 Hat washer
ARP2554304 SVO bbf 9/16 head stud kit
MOR63911 vacuum pump pulley 5 inch
SCP1135-18 18 tooth pulley dry sump
SCP240L100 24" dry sump belt
MOR64885 moroso pulley
MOR23523 4" crank pulley v
AIR BLEED for vac pump
Ross custom pistons 14 TO 1
1.73 ALUMINUM ROLLER ROCKERS
FORD MOTORSPORT PRO STUD GIRDLES (SET)
460/LOGO BBF Polished logo 429-460 tall VALVE COVERS
CRA4.500/S 4.500 stroke steel forged crank
Custom oil Pan
STE6552 Hat washer
