1 - 18 of 18 Posts
557 ROLLER MOTOR FOR SALE
CRAWLER 4.5 STROKE BILLET STEEL SHORT SNOUT CRANK SHAFT CAN BE USED WITH A BLOWER
6.8 H-BEAM EAGLE RODS
JE 4.440 BORE PISTONS
MOROSO REAR SUMP OIL PAN
MAIN GIRDLE
BLUE THUNDER ALUMINUM HEADS WITH 2.25 INTAKE 1.88 EXHAUST NO PORT WORK HAS BEEN DONE
CRANE ROLLER ROCKER ARMS
JOMAR STUD GIRDLE
MSD DIST.
MOROSO TALL VALVE COVERS
VICTOR INTAKE MANIFOLD 4500 STYLE
MEZIERE ELECTRIC WATER PUMP
COMP. CAMS ROLLER CAM SHAFT .762 LIFT
CARB. & HEADERS & FRONT PLATE IN PIC. NOT INCLUDED ANY QUESTIONS PLEASE ASK THANKS FOR LOOKING
$6,000
has about 25 to 30 150 ft runs on it I buit the engine carries around 50 oil psi at an idle. it was in an isuzu pup weighted 3100lb and would run in the mid to low 3's ranges I'm located in Canaan Valley, West Virginia
Were all the parts new when you built it or older stuff you had?
Thanks Tore
1 - 18 of 18 Posts
