1 - 20 of 21 Posts
Selling my boat motor: Maybe 5 hrs. Jeff Stretch built 1000hp 830tq built motor
it is actually a 582 ci
SVO block
scat crank and scat h-beam rods
Diamond pistons 14.1
All arp bolts
MSD Dist
danny-bee belt drive
Comp roller cam around .0745 lift
crane roller lifters
trick flow polished alum heads/chevy exh ports,
crane rocker arms
trick flow stud girdle
polished older trick flow T/r
1050's dominators bme
stefs pan
canton polished valve covers
Power master starter
no expense spared
Motors runs great in my jet boat.
have not used this boat and motor to much this year maybe a couple hours more. motor is super fresh and would make someone a real nice engine
reason I am selling is wanting to go back to a pump gas motor or selling the boat also
This motor is fresh, have dyno sheets, and all paper work.
engine located in So Cal. Will answer ? as best as I can. $15,000.obo
Bob
I am using this motor for 3 days next week at the river. Putting more hours on it. Better buy it before, I keep it. Can't build this motor not even close to what I am asking. OBO Bump
Figured I would bump this fine piece of an engine. since now we should all have more cash with "o" being reelected:(:p:mad: well in any case its still forsale. make offer, before they charge me capital gains.
here's some food got thought...
if your only selling cause you want a pump gas engine why not just swap out the high compression pistons and keep it?
I've got an A460 headed 557 that dyno'd over 900 hp on 91 octane w one 1150 carb...
Discussion Starter #12
Now I just really don't use the boat that much any more. so just wanting to get rid of it.
1 - 20 of 21 Posts
