Im doing a new build but dont know which way will be the best for my pocket book,
I hav a new Ultra block its right under 4.500 bore that will save from getting it bored. I have the C460 heads flow 525,
Ihave the c460 intake also worked.
That will give u idea on what i have already.
So now i need the CRANK ROD PISTONS,& CAM LIFTERS.
So which way will be my best options?
Its going in a 2400# car thats including driver. So it should run deep 4s easy Nos motor build also. Let me hear whst you think on which way i should go. THANKS
With the C heads that flow that much I would at least do the 632.
Can you bore a 429 to 460 bore stroke
Hi Francis,
The 429-460 have the same bore, to turn a 429 into a 460 all you have to do is install a 460 crankshaft, though I believe the early crank won't "drop in" to a later block without some clearancing. I'm assuming you have a 429?
Also, you may find you get more response to your questions if you start your own thread about what you are trying to accomplish.
Dan
