Being a FE guy for a long time, this forum has helped me more than words can express. I gathered advice and parts over the last 3 1/2 years and finally got the car to the track this year. Because, like alot of people with alot of toys and a family to support I tried to put my car together as inexpensivly as possible and knowing the HP potential of the 385 is why I switched. So heres my final combo as of the end of the 2004 season.
seasoned std bore dive block (froze-up).....$50
tank,bore .060(with plates),0 deck,line hone,resize rods,balance, press pistons on rods, install cam brg's and I had a set of truck rods........$628
Pistons FT with 1 eyebrow/12:1 compression,brgs,gasket set,rod bolts,rings and roller timming chain from coast performance
(hard to deal with and waited 6 months for pistons)....$748
used 9 qt front sump pan with pick-up...........$75
New melling hv oil pump.................$66
New pump drive.................$29
Heads I bought from Rick S (thanks again Rick)heavy ported Doves with 2.19/1.72.....$500 (I did roll the edges of the port opening on the Doves to match the CJ intake ports.
Machine pedestals for rocker geomitry and cut for teflon seals........$125
New seal power valve springs 140# seat/400# @ .600 off ebay for....... $58
Lunati #416061 cam and lifters new @ swap meet.......$150
351c push rods from PAW...................$43
New angus 1.8 roller rockers off ebay..............$169
Milodon valve covers from swap meet..............$25
Stock dura spark dizzy with spring kit from autozone and put 5/32 coil pin in........ $57
weiand water pump used ebay....... $42
Weiand stealth cj 8021 used ebay........$147
850 dp used ebay.........$173
New proform 950 body.......$188
Crites 2" headers....$379
Total: $3682
Add oil/filter and some misc.$ and your in under $3750.
I can't afford the parts to switch around to go to the dyno and play. I have to play at the track but that motor got a 4200# merc wagon to run 7.56 1/8's and 11.78 1/4's. The car runs great (consistent)and have had alot of fun and won a little money to boot.Using 2003 challenger engine software I found here and with smokem ups software this combo is making about 580HP. I would say the horses per doller on a 385 is unbeatable but we here already know that. I hope this helps someone starting from scratch like I did 3 years ago. sorry for this being so long.
Greg
Edit Message Delete Message Lock Thread Respond to this message
Author Reply
Anonymous
(Login BB85GT)
64.12.116.132 Re: 580 HP on a buget February 24 2005, 3:28 PM
Is this just a race car or do you drive it on the street? With the 12-1 what type of fuel do you run? thanks, jason
Hpinxs
(Login hpinxs)
130.135.101.155 Coil Pin? October 26 2005, 7:58 AM
What is a Coil Pin?
Bigblock89
(Login Bigblock89)
205.188.117.70 Coil pin..think he meant roll pin December 8 2005, 5:51 PM
The roll pin that keeps the oil pump drive gear in the correct position and keeps it from spinning on the distributor shaft
Robert
(Login bigbub1968)
201.248.5.158 Well Done!! November 7 2005, 5:28 PM
Congratularions Greg!! All your information is very important for all us new to the 385 family...Thanks for the well detailed info!!
1FSTCAT
(Login 1FSTCAT)
198.234.74.102 I don't mean to be the voice of reason, but.. December 27 2005, 6:11 AM
How about some real world numbers? My software says my similar combo should make 452/487, but it makes 225/325 to the rear wheels (although I really think it's just BROKEN). How about some track numbers, or some real dyno numbers?
Jason Pierce
(Login jpierce55)
172.169.212.174 Re: I don't mean to be the voice of reason, but.. December 30 2005, 10:49 AM
Read again he has track numbers and that is what his estimate is on.
