I have a 598 C head combination that i think gets hotter than it should. I usually leave the line at 160 degrees and hit the shut down about 175 but coming back up the return it will go up to near 200. I know i see some guys tow these cars back and forth but i have also seen other guys running mid 8's driving around the pits. It is 14.5 to 1 compression but it seems like it heats awefully fast. The cooling system holds 3 gallons of water with additive but i dont run a restrictor in the intake. timing is a 32degrees...anyyone else have any clue why it heats so quick....more than likely will i be pulling this thing around the track? thanks
