1 - 9 of 9 Posts
I got my car to the track. The first time my convertor was way too tight, only stalled to 4 grand. car would fall flat and then move on after 60 ft. I put 6000 convertor in it now. I have a 598ci motor, 2 speed power glide 1.80 first gear, 4.10 rear gear,29.5x10.5w slick 2700lb car with me in it. Single adjustable front struts(strange10 way) single qa1 in rear. Because of bigger tire my lower control arm the rear bolt is 1/2 inch higher than front.
Ok so back to what the car is doing, with 4000 convertor I got best of 1.35 60ft. car spins tire, hooks spins again and then makes the run.
With 6000 stall setting 2 step at 5200/5600 and 5800 the car spins pulls wheels settles and spins again and the makes the pass. best I got with 6000 stall was 1.25 60ft.
I was told I need more gear, I shift at 7600 rpm and hits traps at 7100/7200. I have racepak. My graph shows engine rpm goes to 6000 rpm and stays flat thru out the 60ft and then climbs. At the same time my ds rpm goes up then down and then climbs.
When my tire spins and ds rpm goes up it does not reflect in the engine rpm. The engine rpm stays flat at 6000 grand for atleast 1.30 seconds into the run.
I know this is alot if its too much to deal with I will understand. below is video of my passes from last night with 6000 stall. This is alot of typing if you feel like calling me its cool, I hate typing. Or send ur # and I will give you a call thx Charles 313-443-5557.
https://www.youtube.com/watch?v=sHptV2xcq0E
here is racepak graph. Red is engine rpm. I belive I had 2 step at 5200 and shifted at 7000 rpm.
Thats flying for a all motor car, I love watching this car get faster and faster, Been to the last 2 Milan NO ET's to see it run
your going to have to change cam,gear,or converter, or all 3. they are not working together
call me tomorrow if you want
I mean...if your not happy with your setup ill suck up shipping charges if you wanta send it to me to "test" :)
Nice build though
Well ..... did you come to a conclusion on what you needed to change?
1 - 9 of 9 Posts
