well its been almost 5 years of hard work and lots of $$$$$ to get my motor done and iam almost done i would like to thank forum members for there advice when i ran in to problems. this is my combo i have changed a few thing's
from other post's on my combo
RDI A96 aluminum block 4.600 bore
c460 intake with 1150 holley dom.
C460 heads with 1.7 crower shaft mounted rocker arm's
Crower billet crank 4.500 stroke
oliver 6.800 billet steel rods
weisco pistons 10.7 comp & hell fire rings
danny bee belt drive
Meziere electric water pump
Crane cam street solid roller 640 lift on intake and exhaust dur @.050 264 intake 268 exhaust this cam runs with 149 lbs closed spring preasure and 380 lbs open preasure and should live on the street it has 114 lobe seperation lifters are Crane ultra pro with pin oilers
the nitrous system is a pro two stage 300hp to 500hp
its goin into my 93 stang coupe i hope to dyno it soon
This message has been edited by Rich.S from IP address 63.189.72.59 on Apr 29, 2005 9:53 PM
This message has been edited by Rich.S from IP address 63.189.72.59 on Apr 29, 2005 9:50 PM
Edit Message Delete Message Lock Thread Respond to this message
Author Reply
theo
(Login theoss)
147.10.74.196 Re: 598 pump gas street motor almost done November 6 2005, 11:20 PM
Hi , was just wondering how you went with your engine and how much power did it make .
Cheers Theo
rich
(Login Rich.S)
64.136.49.225 The motor isnt finished yet December 23 2005, 9:20 PM
it still needs to be put together.and needs headers pushrods etc...i went out and bought 2 more mustangs and iam short of funds at this time lol.
Rich.s
This message has been edited by Rich.S from IP address 64.136.49.225 on Dec 23, 2005 9:25 PM
Bootlegger
(Login 4TFORD)
66.56.196.217 Re: 598 pump gas street motor almost done December 31 2005, 8:28 AM
I am very interested in seeing how this turns out. Please keep us informed. Do you really think this engine will be streetable with a compression ratio of 10.7? What is your "expected" HP rating for the engine? I am currently looking to build a high HP (streetable) 429/460 with Aluminum Cobra Jet heads. Always looking for good input. Thanks for the great info and keep us posted.
Bootlegger
rich
(Login Rich.S)
64.136.49.225 Re: 598 pump gas street motor almost done January 1 2006, 7:18 PM
I built this motor to drive on the street and with the Cam profile iam using it should live fine without any roller lifter issues iam hoping to make 800+ on the motor and 1100+ on the jug of course thats not going to happen on pump gas but it should run on pump gas on the motor without nitrous.i have a much larger cam for the motor but it wont last long on the street without lifter axle failures..when i get it put together i will post a pic Rich.S
