1 - 12 of 12 Posts
A-460 block 4.605 bore, roller cam bearings, bushed lifters, Crower billet rods and crank, 6.8 length rods, 4.5 stroke crank, all std- std, 20 passes since all new, has pistons for Hemi heads now, but could be switched over to C-Head or A- heads pistons easily. $4500
If you need more info let me know
Parts are located in Des Moines, Iowa
What hemi heads is this setup for? Mine are 100 cc a441 heads, what compression would i get with youre short block?
Thanks....
Denny
It is 16-1 comp now with .150 popup could be milled to flat top and be about 15-1 comp, It is set up for latest B-441 heads, if yours are late model heads, they should fit. Thanks
Pics
These are pics of parts for sale, they have not been cleaned up yet. And no, the block has not been hurt. It is an 18 bolt block, but bottom 4 holes on each side have not drilled and tapped yet, as I was using 10 bolt heads. I will be using the beltdrive on my next shortblock, but it can be included on this shortblock for an extra $750. Only 20 passes on everything since new.
You stepping up the cubes to catch the Blue boys?:)
Actually, I'm trying to work a deal on an all alum 648 cu in shortblock, otherwise I'll be running this one this year. See ya round this summer?
I'll look you up if you come to Ravenna again this year.:)
1 - 12 of 12 Posts
