Listing this for a friend:
604 cu in 4.5" stroke billet center counterweight Crower crank
6.8" billet steel Oliver rods
4.625 15 to 1 JE pistons- gasported
A-460 Motorsports block 10 bolt pattern o-ringed w/copper head gaskets
A-460 Motorsports Alum heads CNC ported w/ tit intake and exhaust valves
Cast tunnel ram with liteweight CNC top for Enderle alcohol injection w/airfilter
extra deepsump pan with ext belt driven oilpump
.750" lift Roller cam and lifters [don't have camcard]
Crower roller rockers and stud girdle
ATI balancer and belt drive on crank
Motorsports valve covers
MSD crank trigger and low profile dist w/msd wires
Upright coated headers
Rotating assembly is almost new and the rest is in real good shape
It has the heads, intake, and pan removed right now, for anyone wanting to
look at it
It was used in a pulling application, on alcohol
but certainly could be used in other applications
$9950 Compete with alcohol injection and deep pan setup and ignition
$8800 for just the whole motor
ps the shortblock was more than that new!
PM me for more info
Discussion Starter #2
Still available, heads and pan are off for your inspection!
ps If you are getting the run around from your engine builder [I know that never happens], this ones ready to go!
