1 - 13 of 13 Posts
A-460 svo block w/ 4 bolt frnt cap. steff pan and tank, lite weight XRP plumbing, billet crank, oliver 6.800 rods, total seal ring kit, bearings 25 passes ago, thor heads, CFE cnc program, CFE sheetmetal intake, TRE carbs, Tit valves, T and D rockers, Manton push tubes, LSM cam odd fire, carnk trigger, peterson dry sump, east coast alt, moroso vac pump, mezzere water pump. PSI springs. No major engine failures, crank standard standard, block never welded on. This is a low maintance 1180 hp motor. It gets driven out of trailer driven to the lanes, raced and driven back to pit. $ 38,000.00 This is the 3rd season since evey thing was new. Crank new this year. Trades for over 700 ci with Boss or Thor head pkg.
CFE done the intake and the cnc program, Woody's has massaged them. The intake has a Single and a Dual lid. This is the 3rd season I have used them, valves new this year.
Discussion Starter #13
They are 1st gen and flow 545 in similar port size to a C-head. Heads
complete w/ valves, PSI springs, Tapered push tubes, T and D rockers, valve
covers, and intake, TRE carbs, linkage. New was $17,000.00 sell
for$12,800.00 Valves new this year, springs have 50 passes all guaranteed .
Craig Sullivan 317-445-2663
1 - 13 of 13 Posts
