just like the add says, 63/64 roundback ford/edsel housing with big bearing ends, i pulled this thing out because it wasn't going to be strong enough for my 557 and from the pics you can see where it was trying to roatate the housing upward thus causing the u-bolts to where thru the powdercoat and a little on the housing
housing is empty with the exception of pretty new axle seals, this housing is good up to i would say 600 hp any more than that i would grab/make a new one like i ended up having to do
would like to get $100 obo plus shipping from 88130, this thing weighs roughly 50 lbs ish.
thanks
rick
[email protected]
850-218-6130
not the housing, you scould have one made out of 1/2" thick tubes and will still do that. spring perch needs to be gusset .
