63 galaxie c6 speedo cable
1317 Views 2 Replies 2 Participants Last post by  chris466c6
Hi.
I've got a 63 galaxie with a 460 and c6. The speedo cable is broken.
What cable should I get? An original Galaxie speedo cable or a cable from a C6?
will a C6 cable fit into my stock speedo instruments?
The speedo has never been accurate and I do not know which cable is in there at the moment. The original trans was a cruise-o-matic.
thanx, chris.
1 - 3 of 3 Posts
I would think a factory cable with the proper bullet on the end should work for you. When I but the 521 and C6 in my 67 Fairlane ( original 289 C4 car) the speedometer cable works just fine outside of being off, I need to get the proper Bullet for the end.
Good luck
Dave
ok, thanks a lot.
I'll give the original cable a try.
chris
1 - 3 of 3 Posts
