Some of you might remember my COVID 532 build for my son’s 70 Lincoln Mark III. (AKA Hot Rod Lincoln)
I nabbed my dream car back in April, a 65 Galaxie 500 LTD, 352 auto, PS, MANUAL brakes😂 no radio, no AC,
NO RUST 😎 (to be known as “Demon Slayer”)
In the process of replacing the entire suspension with PMT Fabrication components (excellent product, if you have time to wait for it) I am planning to drive this car as-is next spring/summer while I build the powertrain to be installed (hopefully) next winter. Body will come off frame in fall, frame to be blasted & painted after remaining fabrication is done (upgrade rear to 4-link, install engine/transmission, etc.) haven’t weighed it but I’m guessing it’s around 3600-3800# as it sits. Full interior will remain, stock hood, might add cage at later date (will decide while body is off) this is going to necessitate a ProCharger to keep everything under the hood.
Final goal for this is a 10.00 street car. I’m thinking 1000hp MINIMUM for the street and have pulley/tune combo to get 1200-1400 for track use.
Will be going one of two directions.
If someone comes up with an affordable front sump kit for the 7.3 Godzilla that, and a 6R80, are probably my first choice.
or
Build an Eliminator street/race block 572 (4.600 x 4.300), I’m told they will machine 2.250 cam tunnel for std bearings.
I prefer flat tappet for street use, ideally hydraulic. Transmission would likely be C6, although it’d likely need to be full manual at this power level and I’m not sure how well that will hold up on road trips.
Pump gas would be ideal, but E85 is plentiful here.
more pics to come.
-Earl
or
more pics to come.
-Earl
