Al Drews Off Road Racing 668 HP Ford Big Block
460 Ford Big Block (472 Cubic Inches)
668 HP @ 6600, 605 Ft-lbs 4700 RPM - with dyno sheets, from Thompson Automotive.
7.5 hours since freshened, in excellent condition.
Built and tuned by Thompson Automotive Race Engines, Redford, Michigan
SVO Cobra Jet Aluminum Heads - FERRA Stainless Steel Valves, ported
and polished
SVO Single Plenum intake, port matched
SVO Cam
SVO Roller Rockers, 3/8" chrome moly push rods
Eagle Rods, TRW Dome .030 over pistons, 13.0 to 1 compression ratio
High volume SVO oil pump and chrome moly oil pump drive
Deep rear sump oil pan with crank windage tray
Double roller timing chain and gear set
High volume aluminum water pump, with 1/4" front motor plate
All ARP Fasteners Used
Complete minus carb, distributor, flywheel, and pulleys.
Can hear run, still in race truck.
Go to www.lucasoil.tv, Motorsports Hour #48 to see #32 Al Drews Racing Ford on
the track in Weatland,Missouri.
Selling to build 900 +HP motor.
Call Al Drews at 734-502-7458.
