21 - 27 of 27 Posts
CC on the head was 74cc nominal. Heads were milled but only to resurface the deck. Also, very little grinding was done in the chamber itself. I had 4 cc's in a single valve relief on the piston. A 557 inch engine makes getting high compression very easy even leaving the piston down from the deck a little.
I did expect/want the engine to peak at about 6000rpm. With this cylinder head and displacement the ports get very high velocities at even moderate rpm so horsepower and torque tend to peak early. I was glad to see the torque peak under 5000rpm too. What's deceptive is that the engine doesn't really "brick wall" at 6000rpm and it doesn't really fall off much at all to 6500rpm which is about as fast as the customer is going to rev the engine.
Large engines can really swallow a lot of cam timing yet still remain quite tame. I had it idling at about 1200rpm on the dyno and it sounded surprisingly mild.
Thanks Dave. Yeah I forgot it was a 557 when I asked about the CR. I'm too used to small 460 sized engines.
Sounds like it has a really nice power curve and good manors! Thanks Steve
I would actually like to add an update to this engine post, I am the owner of the engine, it has been an amazing journey, still runs great, we regularly run this engine 7,800 rpm, and with a 250 wet shot of nitrous, using 114 octane in the nitrous fuel system and 110 octane in the regular fuel system. This engine, stock block and cast iron heads, has never had a catastrophic failure as hard and as far as we push it and has only been opened up 1x in 10 years. If you ever want the best engine built by all means see Dave Mclain ! It now is going to be put in a 1965 galaxie 500, since it wont die..
This has always been one of my favorite builds.
Dave is a stand up guy and a real talent !!!
"EMC 2006" 3rd place finisher
Custom ground cams
Customized crate engines
ParklandAutoMachine.com
R-H-P.biz
(253)-988-6648
Parkland Auto Machine
21 - 27 of 27 Posts
