I just picked up a 75 highboy with an FE and NP435 4-speed. I want to eventually put a BBF in front of the tranny but have heard the 351m bellhousings aren't deep enough...the pilot in the 460 crank is too shallow and the input shaft on the tranny bottoms out not letting the bellhousing bolt up to the back of hte block. Is this true?
How much spacing needs done? Does anyone make a spacer plate of the correct thickness to put between the tranny and a 351/400m bellhousing? I heard someone made special bellhousings for this swap but that sounds expensive.
