1 - 7 of 7 Posts
Hope Larry T doesn't mind me copying his build...
my 552 build started 4/08 drag only motor for 3000lbs 94 mustang with powerglide 9'' rearend with 3.89 gears.i was hopeing to get the car done befor the end of fall but that didnt happen.
D1TE block .060 over.
diamond flat top scj pistons .0128 average in the hole for about 13.2:1.
scat 4340 6.7 H beam rods.
scat 4340 4.5 crank internally balanced.
ford motorsports timeing chain set.
kaase p-51 heads +.100 valves Erson springs and titanium retainers "unported".
victor 4500 intake with the carb ears trimed to match carb gasket only.
comp cams roller cam pt# 34-000-9 gross lift .757in .766ex duration 278in 288ex .112 lsa.i may use a wet 150 shot of nitrous
comp roller lifters.
lanati 1.7 rockers.
Hytec 3/8's x 9.100 and 9.300 push rods.
Jomar stud girdel.
Holley Quick fuel 1250 dominator carb.
Hvc 1" super sucker "10tk & 15hp gain" and 1" open spacer with a gain as well 2-3hp & tk.
dinoed with 2-1/4 cheby headers with charlies adapter.
Kaase oil pump.
rod and main bearings were setup with .0025 clearance.
royal purple 15/40 oil and it did make a slight differance in hp and tk.
28.5* total timeing.
motor is setup to run 112 race fuel.
5000 736tk 700hp
5100 738 717
5200 735 727
5300 730 737
5400 725 746
5500 722 756
5600 723 770
5700 720 781
5800 719 794
5900 718 806
6000 712 814
6100 707 821
6200 699 825
6300 690 828
6400 683 832
6500 672 831.4
6600 662 831.4
6700 651 831
832hp with "Un-ported" p-51's ..... wow that's impressive ;)
Why un-ported may I ask ? I need to look at the head archieve to see what they flow.
Edit: Now I see why, I didn't know the P-51's flowed 412 cfm @ .700 stock... that's good to know.
G-Code :D
Nice build.
A
Guest
i was doing a post in the car build up section of everything i have done on my 94 mustang build and it has gone with the Wind.maybe i should have worded it different?did i get a speeding ticket chilly?i cant afford anymoor tickets....
here is the link to the motor build.
http://www.460ford.com/forum/showthread.php?t=121183
Larry, you did nothing wrong at all. I didn't touch your car build thread. I just wanted to grab your motor build and put it in here, because I thought it was a very nice combo. Hope that's alright, didn't figure you'd mind as you had posted all the details.
the motor build is on the second page of this forum.i copyed and pasted the motor build to go with my chassie build so everyone could see it together.i noticed my thread was moved to the tec forum,can you move it back to the build forum?if you want you can delet this?
1 - 7 of 7 Posts
